Adam_Dawg78
I posted about this problem previously and am still going through to try and find the problem. Here is a brief history.
December had misfire code, replaced all spark plugs. Month later problem happened again, went back in replaced all plugs, broke a couple of connectors so I just secured them back with tape.
Shaking became more noticable. But power steering was acting up too. Fixed power steering by installing new Pressure Switch. Shaking still there.
Went back in and replaced the electrical connectors that connect to plugs. since I had the intake off, I replaced gaskets, pcv valve, pcv elbow. DPFE Sensor, EVR Vacuum Soleniod. After putting back together had to go back in and replace the o-rings on the fuel injectors that I messed up.
So now everything is back together and shaking is still present.
It shakes when stopped. At low idle, evens out and shaking isnt present past 2k rpms. Then around 50mph shaking occurs again. not as bad as idle/low rpm. I cant get a code to register. It seems to be worse at low rpm, when shifting into reverse and reversing slowly and shifting from reverse to drive. I ended up doing this multiple times, not applying gas just letting the car go a little forward and then same in reverse and the car died. did this twice. Still no code.
I ended up going to the auto parts store and bought a new IAC Valve and EGR Valve. I havent replaced the EGR vavle yet, but I did do a test on the existing one. I hooked up a line to the vacuum line that connects to the soleniod, cranked car and applied the line to the valve, few seconds later it started sputtering and almost died, took line off engine back on, applied again, this time it seemed to want to stall but never got there. So Im still confused about this part.
I decided i would replace the IAC Valve on the car first Cranked it still noticed some shaking, but the odd thing is it stayed at a very high rpm, never settled back down. then it all of sudden did and died. Cranked again and revved it up, it idle at about 1500 then slowly started to accelerate. Turned it off. Cranked again, and finally after staying around 1500 dropped back down to about 900.
I thought maybe they gave me the wrong valve, but I checked it out online and its the right one. I have just cleaned up the old IAC Valve about to go put it back on and see what I get.
I will be checking back here, so if anyone has any theories or has had this problem please let me know. Is there anything else you think it could be, would a vacuum leak or lmass air flow sensor do this?
