bamaguy
UPDATE - PLEASE SEE LAST POST AT BOTTOM
My fiancee has an '01 v6 LS. After many overheating problems and doing ALL the fixes, I installed an electric fan. It has been blowing fuses since I first installed in a few months ago - at first, once in a while, now almost immediately. When it blows the fuse and she doesn't notice, it overheats and sprays coolant all over - possibly on the wiring.
Initially, it would burn up wire connectors, before a fuse would blow - I believe they may have gotten wet when degassing after the coolant re-fill. The car would run fine for several days, maybe even a week before this would happen. I re-wrapped all of them, then one of the 25 amp fuses would blow. When I changed that fuse with a 30 amp, the other blew. The aftermarket cooling fan harness I bought from O'Reilley's has two 25 amp fuses - don't know if they are in parallel or series. That relay was complicated with temp sensor circuit and AC compressor circuit.
I re-wired all of it today with a simple 4-pin 30 amp relay to check everything and it blows a 25 amp fuse instantly. When I switched to a 30 amp fuse it didn't blow after about a minute, but it was starting to smell like it was burning. I have ground direct to chassis, a full-time hot 12v from an open spade in the fuse box, and a 12v switched power source that give power then the key is turned on.
Any ideas?
Any ideas?
