Updated The dreaded misfire
wrt01
Kingsport
Well on Monday it went from bad to worse. The car was shaking and had absolutely no power! Finally the check engine light came on. Read the codes and #3,5,6 had a misfire..... put new coils in. Problem is tremendously better but still has a slight misfire between 1500-2300 rpm. Do I still have other coils braking down or what? Went ahead and replaced the fuel filter. I have a slight hesitation when pulling out, say from and red light. What do you think?
Spend the money. Get it checked. It may be a lot cheaper than just throwing parts at it.
wrt01 said:
I have spent the $$! to get it checked!! They said it was coils.........
I'm sorry....I didn't see where you mentioned having it checked out. But if you took it to someone to have the miss fixed, they diagnosed and replaced coils, and it didn't fix it, TAKE IT BACK! They shouldn't charge you for the repair if it didn't fix your complaint.
