JERSEYJOE
Has anyone replaced their uppeer control arms? my right side upper is loose enought that I can hear it rattle when I go over bumps. It's also loosewhen you jack the car up. I understand that the ball joint is part of the control arm, and I want to replace both sides at the same time.
Anyone done this? How hard is it to do? Since the camber adjustment is in the lower arm bolt, I should not neet to have it re aligned.
Moog has them for around $80.00 per side
