JayBay
I installed an upper control arm on the driver's side of my 94 yesterday. Any of you who have done this know what a pain it is to get to the rear bolt. I found a whitepaper (on another site) indicating this can be done with a ratchet extention and a pivot through the factory provided access hole - which is the best way to get to it. However, my little modification I think makes it easier to work with. I extended the access hole with an air-powered body saw, making sure I was only penetrating about 1/2", so as to not damage anything behind the metal. The larger access hole made this job much easier, and only took a few minutes to cut. I figured it's getting covered by the inner fender anyway, so why not? The picture shows a dotted line where the factory hole was. Hope this is helpful.
