Motts
is a STOCK v6 burnout possible?
Motts said:is a STOCK v6 burnout possible?
Motts said:tried it this morning, they just squak a lil.. no smoke or anything..
Motts said:i have the v6 which is Front Wheel drive... The v8 is rear wheel..
Jim Henderson said:Mashing the brake and flooring the gas (Power Braking) is not a good thing if you do it for too long. The transmission fluid will overheat which will cause damage if it gets hot enough, which it can faster than you would think.
The V6 probably doesn't have the power, but power braking an auto can also cause the torque converter to "balloon", effectively destroying the converter and also potentially killing the tranny too. I doubt our trannies and converters are designed to handle abnormal use like power braking.
Power braking is only "safe" in a tranny properly modified for such "abuse". You can get away with it most of the time but if it fails, it will cost a mighty nice bundle of cash.
Just enjoy your car. Smoking tires is not the best use of the power you have and it at best wastes rubber, and looses traction and at worst, you get a new tranny. You will notice the professionals only smoke em in the bleach pit and that is only to clean the tires. The winner rarely smokes off the line. Smoke means your horsepower is being wasted.
Good Luck,
Jim Henderson
stateproperty3423 said:how good does it spin when you rev the engine in neatrual and the shift into drive
didjital| said:I wouldn't advise neutral slamming it.
mark0101 said:I had a ls for two days as a rental car. 2005 v6. I tryed to do a burnout but I couldn't. I just punched in gas and it still wouldn't spin. I don't know but the v6 are hard to spin. It has more hp than the town car, so I was suprized it couldn't do a burnout because all you have to do with the town car is punch in the gas and it will spin for about 3 seconds.(Till 20mph)
