V8 Fuel Temperture Sensor
allkesh
your moms house
2002 LS V8 SST
I read the OBDII when i got a check engine light & got code 0181.
Telling me my Fuel Temperture sensor isn't working properly. Problem is i dont think the V8 comes with a fuel temperture sensor only the V6 does.
Does anyone know about that?
I do not believe any LS has a fuel temperature sensor. News to me.
According to obd-codes.com, P0181 is
P0181 Fuel Temperature Sensor A Circuit Range/Performance
Never heard of a fuel temp sensor on a production car.
Then there's U0181, which is
Lost Communication With Headlamp Leveling Control Module
I also found this, which might be helpful, as it specifically discusses the P0181 in the second post:
http://www.obd-codes.com/forums/304-obd-codes-p0171-p0181-question.html
I think that my thermostat is going bad. It takes a while for the engine to warm-up, thinking i am hitting the time limit for the closed loop engine management & the code is a result.
