Very Loud Car Audio..
1stGenRYDAH
Wadsworth
I have two 12" Audiobahn AW1208T 3000 Watt max per Sub
Technical Specifications
Sensitivity: 90 dB
RMS Power Range: 1500 Watts
Max Power Range: 3000 Watts
Impedance: Dual 2 Ohm
Low Frequency Response: 20 Hz
High Frequency Response: 500 Hz
Diameter: 12 Inch
And a Audiopipe 3000 Watt Class D Mono Block amp that is totally underated.
Its all located in Tallmadge Ohio and is hooked up if your in the area you can come listen and take a look at it. Pics are available upon request and There is a Custom made Slot ported box with candy red fiberglass in the slots. Fits in the Lincoln LS Trunk perfectly!! Price is 900 OBO.. Remember it is OBO...
i just want the sub show much?
