PrOjEcT_LS2000
Alright guys, for those LS engine experts... I have a 200 Lincoln LS (191,000 miles) I've searched for the answer but can't seem to find what im looking for. Some stories are close but not quite like my experience. My issue is that I have a strange vibrating/rumbling coming from underneath the front end of the car. I did have a couple of problems that I did get fixed which included a vacuum leak and a severe oil leak. All together the mechanic replaced, intake gasket kit, PCV valve assembly, PCV elbow hose, all spark plugs, valve cover gasket, 3 ignition coils, 3 ignition coil boots, and a fuel injection...about $1800 dollars worth of repair. Engine light got fixed and no other codes are appearing from the car. After all the fixes, i still have this vibrating under the car, sometimes light and then at times it vibrates the whole car. It happens when i brake as I'm going into a turn, when i put the car in reverse, and sometimes just at a normal stop. The mechanic took it through a road test, nothing wrong with the tranny and the car is shifting fine. They took a closer look, lifting my LS with it running because they thought maybe my exhaust were touching parts of the car it shouldn't in which makes the vibrating occur. That was not the case, instead he insisted that both motor mounts were bad and need to be replaced. Said that the oil leaked onto them and weakened them. Does that sound correct?? I hate going to multiple mechanics being told several different things. So far this mechanic has been correct and solved all my other problems.
