VRCM Replacement
94m5 said:
VRCM? gimme a laymans term to describe it.
The VRCM is located in front of the radiator. The top is bolted to the crossmember that goes across the hood. I am just wondering if there if there is a way to get it out without having to take off the bumper cover.
I replaced mine in a dark driveway, after I had..."overindulged"...all that night, then suddenly remembered I had to go on a road trip the next day. :p Even in those non-ideal conditions, it only took 15-20 mins.
I removed the trim above the radiator, as well as the hood latch. In retrospect I don't remember if that was completely necessary, since I ended up reaching up through the bottom of the bumper cover to swap it out. But either way it was easy and didn't involve removing bumper cover.
allright I feel REALLY embarassed here....What does this thing do. and why are you replacing it? I've never had a problem that involved this.
Mike
VCRM--variable control relay module.
Controls the speed of the fan, ac clutch engagement and several other things including the fuel pump.
Mike, I want to replace the VRCM first because I took my Mark to my mechanic to have the codes checked. I've been seeing my check enging light come on while I was sitting still idiling, And when I am gradually increasing speed from 0 mph up to 50 mph. The diagnostic came back lean fuel bank 1 and bank 2. My mechanic said sounds like the fuel pump is going out. I believe this could be why my mileage has gone down so much. The other problem it came up with was the Variable Relay Control Module. I have a VRCM I bought. I want to replace it first to see if that solves my problems before I go into replacing the fuel pump.
