Want to hot rod '92-'97 Seville/STS
Lee Owens
Afghanistan for now
What's the scoop on reprogramming the computer for better performance? I've heard it's possible and I've heard it's not. I want to turbocharge it. BTW I don't own one right now. I'm a soldier leaving for Afghanistan soon. I'm getting one when I get back.
Thanks, Lee
Reprogramming the computer as in putting in a performance chip or reprogramming the computer to handle the turbo charger?
There should be a performance chip that works for your year, but concerning the turbocharger -- you can't really get one until someone conquers the computer to handle it.
I remember a company called STS being able to turbo and bypass the computer (at least that's what they said) -- but it's expensive.
http://www.ststurbo.com
If I remenber right the hood is pretty cramped with the engine on those sts and a turbo setup takes a good bit of room. These cars don't seem big on super or turbo chargers. I would probably say getting a port and polish on the heads at say fox lake and maybe different cams beyond that. Then a chip/tune to control it. But you may need to have it done with a dyno as opposed to teling them what you have espically to get the most out of it.
i have a 93 STS and if you can fit a turbo in that... pass on the teachings, because your freakin yoda
Well anything can be done if you have the cash, but with that car I would consider nitrous rather a turbo or super charger.
Actually tackling the '93+ N* engine computer has ended up being more than just an issue of money :Bang
If available, I would recommend charging and then adding nitrous around that than the other way around.
Nitrous set-up on a Caddy is fairly easy.
you could
right now i'm in larimie, wy elevation 7100 ft and just had to unhook the battery to make it adjust to the altitude i don't know if it will work for you but it won't hurt :C
Thanks, Lee
I recall a couple years ago discusion about the development of a super charger for the STS pushing hp north of 400. Pardon the pun.
