Ex: The ones commonly found on Ebay with the monitors built into the headrest.
And not really a warning, per se...but more of an FYI
Ordered and received a pair of Innovatek headrests with 7 inch monitors built in. While they will fit into the headrest holes, you may want to use a dremel to cut the "notches" into the support pole, in the same location where the stock headrest has notches in it's support pole. The notches keep the headrest in whatever height position you have it in/keeps the headrest from sliding down unintentionally.
It think it's also important to note that while the Innovatek headrests will fit and look good, they will not fit your "head" like the stock headrests do. The Innovateks are not as "thick/round" as the stock headrests, not shaped the same, and as such, do not extend forward as much as the stock headrests do. It's going to take some getting used to not having as much neck/head support when driving around.
Just an FYI
Just an FYI
