"Washer Fluid Low""
Codav
Castaic
Hi,
I've had my 96 Mark V111 for about a week now. When I first got it the system said my "washer fluid is low" Sure enough it was low. I poured almost a full jug of the blue liquid into the reseivoir. The windshield washers work perfect but the warning light keeps telling me I need fluid. Interestingly, when I first start the car and perform a system check it tells me it is fine. The next time I check, only a few seconds later, it tells me the reseivoir is low.
Is there a way I can reset it or is it a software problem the dealership will have to reset?
I've learned a lot about my car through this site.
Thanks,
Jerry
Codav said:
Hi,
Thanks,
Jerry
To reset the system, just remove the negative wire from the battery.(for a few mins) I don't if this would fix the problem.
maybe the sensor inside the washer fluid thing is broke?
i get low engine coolant every once in a while, especially if i am parked at an angle or if the car was in the cold - even tho the coolant level is fine. just a quirk of the car.
I had the same problem with my old 93. tracked it down to a wire that was shorting out after the switch. I doubt this is your problem, but it's an idea.
Mike
Low wiper fluid reading
Thanks for the advice. I really thought this would work. I couldn't remove the negative terminal, seems like the clamp is almost welded on. I was able to take off the positive terminal though, left it off for a few minutes, then replaced it but with no luck.
Thanks,
Jerry
