vt solo2
Hi everyone, I've searched the forum and didn't find anything, so hopefully I just didn't miss it. I have a 2000 LS and the driver's side windshield washer sprayer on the hood stopped working a couple of days ago, the passenger side one works fine. I opened the hood and pulled down the padding on the hood (which was wet with washer fluid). I found that the rubber hose came off of the plastic connector on the nozzle. It looks like the plastic connector actually broke, a piece is stuck in the rubber hose, and there is a spring sticking out of the plastic part that's in the hood.
So my question is, what do I need to fix this? Is the plastic connector separate from the nozzle or is it one whole piece? Also, how do I pull the nozzle assembly out of the hood so I can fix it? Thank you!
