Pepsi2185 said:Is the carpet wet as well?? On some cars there are rubber plugs down there, it may be coming from teh bottom up
I'm new & I could not figure out how to start a new thread, so I'll barge in on this one, if that's OK, I hope..
Has anyone tried this new Mr. Clean no dry car wash? If so does it work?
Ted Evans
04 Black CTS :C
codewize said:My STS is 89 and has the same problem. Thats how I found it, by cleaning the trunk one day I took the spare out. Swimming pool. Bad news.
Roy said:You are right it's 98 to 2004
I think they all have the same problem, some guy's cut the seal to make drain hole but I don't like that idea. I claened it well and used a silicon base sealer to seal the trim and so far so good, no water yet. let me know what works for you.
I will give mine another week before i am convinced that it worked
I too still find it damp some time but the nothing like before, mabey the sunroof is another problem?djKale said:I had the exact same problem, 1999 STS, did some searching and found the same thing you did. The water will almost always leak into the spare tire well at the trunk latch area, but the leak is usually located somewhere along the trunk weatherstripping, not necessarily at the trunk latch.
I pulled the bottom half of mine off and threw on some black RTV sealant. I used a hair dryer to keep everything clean and dry. It's been a few weeks now with rainy weather and no signs of the swimming pool that used to be there. I do still get some dampness in the rear of the trunk, but I noticed that when you open the trunk, water will slide off the trunk lid and onto the carpet. The spare tire area is dry so I'm considering at least one problem solved.
Kale
Katshot said:Ted,
To start a new thread, you need to go to the "Forum" page. You can't start one at the thread level. Oh, and BTW, the Mr Clean stuff sucks!.
an01sts said:Trunk weatherstrips and sunroof drains are usually not the source of waterleaks, but they are the areas of which people look for leaks. The reason that it's just damp is that you're not driving it in the rain, as you drove it in the rain when you picked up water.
The commom problem with Seville leaks is in the trunk seams, but you cannot seem to tell the tech who works on the car. Pull the lower trunk liner. The leaks are at the seam where the quarter panel and tail panle meet. The other leak is at the seam where the quarter panel, wheel well housing, and trunk pan meet. If you hose those areas, meaning inside of the wheelwell--agresssivly, you'll find the leak.
Ed N Indy said:I have taken my car back to Cadillac for the 3rd time for water in the trunk. They cant seem to find the leak. They have replaced the rubber seal. Still leaks :C
Roy said:I read somewere to fix this you need to cut the seal 2 inches in from the curve on each side. has any one done this and how did it work? I have a 2001 STS and my spare and spare well is allways wet?
joestock4 said:Roy, I have a 1999 STS just discovered 6 inches of water in trunk --do you have any idea if there was a recall for a repair to this problem? I read your earlier posts. I water tested and found it seaps in along ledge where deck lid and car meet. Seal looks okay. Other thoughts? Rains too much in Michigan to just not drive it.
