Weather Stripping
KD00LS
Minnesota
Anyone Replace their own weather stripping, was it hard or easy, and where did you order it from?
I replaced the one around the inner trunk - $80 from the dealership - it's all one molded piece.......
If theres two things that make me mad about the car, it's the weatherstripping and the B pillars, makes the car look like :q
Weather stripping is easy if you get factory pieces.
Remove the old strip. Clean the surface well and remove any grease or gummy stuff from the sheet metal. I use rubbing alcohol and paper towels.
It helps if you have a buddy to hold the stuff so it doesn't flop around. Don't stretch the stuff or pull it as you install, other wise you will wind up with too much left over on one side or as the stuff shrinks back it will unglue itself.
Good Luck,
Jim Henderson
