Hi to all!
Recently I have noticed a weird thing in my A/C behavior and currently have no ideas where to dig to localize problem.
Once the problem appeared on my LS ('2000, V8) while idleing a couple of days ago from all vents A/C started to blow hot air (maybe one side was warmer and the other hot). After about hour when car got washed I started it again and all the way home A/C was working fine. Next two days everything was fine too and yesterday while driving (about 40mph) I got the same thing that suddenly got hot air from both side vents, after playing with temp switch (from max cold to max hot and back to prev temperature) everything returned slowly to normal. When parked my car I switched it off and then started again and everything was fine, so was later in the evening and today morning (also left car to idle for a while, but problem did not appear). Still it is summer here and would like to localise problem ASAP.
Thanks in advance for suggestions. Dealer here is not an option as I live in Latvia (Europe) and there are no Lincoln dealers, only Ford dealership that is not very helpful and familiar with Lincolns. DCCV was changed some 3 years ago and I have driven about 20 - 30k miles since then. Also had a problem with DCCV wireing on the right side behind the right side, but it is fixed now too. Few month ago changed also coolant recovery tank that was cracked.
