weird noise
guillotm
Clarksville
I heard a noise today that kind of threw me off guard. It's like a squeaking noise at speeds around 40 and under. Whenever I brake the noise goes away. It almost sounds like a plastic to metal squeaking noise. It does it when I go over bumps but not when I push down on the front of the car. Could someone please give me some insight into this.
I had a noise similiar to this... was a clickin noise, happened to be a loose lug nut.. :Bang
then the squeakin noise, which meant me breaks needed to be replaced.... When did you have your breaks replaced, or have you yet?
They are fairly new. Still have a lot of pad left on them. I will go check the lug nuts. Thanks.
