00NORCAL V8
to safely remove the residue from taking off the vinyl eyebrows on my headlights? TIA
00NORCAL V8 said:to safely remove the residue from taking off the vinyl eyebrows on my headlights? TIA
First just peel the vinyl off. It should come off without any difficulty. There are two ways that you can safely remove the residue left over. You can use some Goo Gone. If you use it just try it in a small corner to make sure it doesn't spider web the plastic. The second way is to use some rubbing alcohol. Just use it liberally and it should peel up. After you have most of it up you can use some non-abrasive polish to get the rest of it off.00NORCAL V8 said:to safely remove the residue from taking off the vinyl eyebrows on my headlights? TIA
GrayGhost1 said:First just peel the vinyl off. It should come off without any difficulty. There are two ways that you can safely remove the residue left over. You can use some Goo Gone. If you use it just try it in a small corner to make sure it doesn't spider web the plastic. The second way is to use some rubbing alcohol. Just use it liberally and it should peel up. After you have most of it up you can use some non-abrasive polish to get the rest of it off.
