Should search the forum, there is even a topic on it right this moment on the front page. Add to existing same topic threads rather then starting another.
Rear tie rod ends ?
There are upper and lower control arms, rear toe adjust linkages and rear sway bar end links.
Thank you!Rear tie-rods are called rear toe links.
Front tie-rod ends are called tie-rod ends.
(The rear "tie-rods" aren't just "ends," unlike in the front.)
No, I'm just a noob. Of course I appreciate all the help and input I can get! Thank youGift,
By the title of the thread... I assumed you were looking for the rears. If I gave you the wrong information,,, I apologize. I assumed... because the fronts ARE called tie rod ends.
edit: I think it was the dealership, not you, that led me astray..... They called them rear tie rod ends and links and I've been scratching my head this whole time until now because I couldn't find any "tie rod ends" for the rear.
