What type of brake fluid for our cars?
67Continental
Montreal
DOT3 or DOT4?
Manual says "Ford Heavy Duty Brake fluid", so not much help there...
Dot 3 on my cap. 98 LSC
I use Silicone Brake Fluid (DOT 5?) in my show cars as they sit for long periods and Silicone does not have the moisture issue reg fluid has. I replaced everything Master cylinder lines flex hoses, calipers, etc when I switched as it is not 100% compatible with other fluids. Only issue is getting all the air out - Silicone has a tendancy to absorbe air.
Best issue for me is it wont hurt the paint!
DOT 3, DOT 4, and DOT 5.1 should work fine in our cars. One of these days I'll replace all my fluid with 5.1. Cheaper than throwing on drilled and slotted rotors.
Type, Dry boiling point, Wet boiling point:
DOT 3, 401°F, 284°F
DOT 4, 446°F, 311°F
DOT 5.1, 518°F, 375°F
Dot 5 is silicone based and I'd avoid it, but 5.1 is still glycol.
