wheel bore size vs. vehicle hub size??
mayhawboy's LS
Huntsville, AL
I'm considering a set of Hub Centric rings for a wheel/tire vibration problem on my '01 LS V8 Premium with the 17" chrome wheels. Does anyone know the wheel bore size and hub size on this car? I don't have a micrometer or adequate measuring device to measure for myself.
INNER DIAMETER: 63.90mm
OUTER DIAMETER: 73.1mm Fits most 85% aftermarket wheels: ENKEI/VELOX/RH/ADR/RSL/&MORE! Double check with your rim manufacturer!
do a search for "hub centric" on e-bay - you may find some there
Quik, thanks for the info, i'm actually trying to solve a possible prob. with my stock wheels. I researched many sites carrying hub centric wheel rings that addressed many aftermarket wheels, none however for stock OEM wheels.
Quik LS said:
I thought the LS used hub centric rims (vs bolt centric) - no?
I really don't know since I haven't had a set of OEM wheels in well over a year. As much as I remember you could use hub centric rings on the OEM rims but I may be wrong.
Aren't the lug nuts tapered? If so, doesn't that indicate that the wheels are centered by the lugs? Otherwise, you may not get the lugs seated squarely on the wheel tapers. Or am I all wet???
we'll see when the hub rings come in. Just got home from another 700 miler and i'm getting more aggravated with each trip.
