Wheels for Sale
KD00LS
Minnesota
5x108 bolt pattern, 18x8 Stern ST-1's in Gloss Black
Come with 255/45R18 BFGoodrich KDW-2's
80% tread, good condition.
Looking for around 1300, let me know. Will fit newer Mark 8's
when you say newer mark 8's....what does that mean exactly? bc as far as I know, gen 1 and 2 have exactly the same bolt pattern and offset...
What is the offset/backspace of the wheel??
An 8" wide wheel gives ya quite a bit of space to work with. Fitment should not be an issue from Gen to Gen...
Brad
Brad
36mm offset, backspace... if you mean for a mk8 I own an LS so I wouldn't know.
36MM if perfect for a MarkVIII...With an 8" wheel you can use a +25 to +40MM offset and be fine. I would rather it be somewhere in the middle of that though...Like say +36MM...:p
If the specs he has on them are correct I would say anyone interested in these should JUMP on them. Nice looking wheel.
Cheers,
Brad
Cheers,
Brad
They should be fine, I know the mk8's have pretty big wheel wells, I know a few guys running 275's around here.
Better pictures... http://forums.bimmerforums.com/forum/showthread.php?t=565290&referrerid=56200
