poniesviii
I might want a kit, AND, I want his opionion on a concept of mine...
If you're around, Send me a pm?
Thanks man.
Thanks man.
my timer relay completely crapped out and filled with water. Mike, If you can hook me up with some type of schematic on wiring 2 switches to control front and rear ride height.04SSHD said:My switch stopped working, I need to find his email again and send him a message.
mespock said:I think he's got a new job... taked to him last week. He went to Buford's and pick up Buford's engine and then sent me Buford's calipers. So Ray is alive and still around the site.
MarkVIII93 said:my timer relay completely crapped out and filled with water. Mike, If you can hook me up with some type of schematic on wiring 2 switches to control front and rear ride height.
poniesviii said:I'm also curious if the front of my car would be tolerable going down the road with NEW front strut assemblies and a bump stop delete? If you're reading this Ray, I'd appreciate your input on that. You know how the front of the car gets bouncy when you're cruisin' extra low, yet the back doesn't. Maybe without those bump stops it wouldn't bounce like that, giving the extra 1/2 to 1/4 inch or so might just be all the more space it needs in the bags to be tolerable. Hitting those bumpstops throws the car up. So as long as the bag didn't bottom out, it would probably sail smooth. Curious what you think. Otherwise, I might have to find a way to take the time and fabricate a setup using aftermarket bags/strut assemblies like I see on alot of 'custom' kits.
poniesviii said:Thanks guys. Someone pm'd me his number, I figure I'll try to catch him afternoonish.
Curious, how much does he usually want for a 'switch'?
thank you brother man.94m5 said:You happen to be in luck my friend. I'll get in touch with Jeremi once he gets back from Poland, and have him wire you one up when he has the time.
ursojp said:if anyone needs him im his little brother. if you pm me and i will get you his cell number. he is having problems with his computer, and he had a new job where he wont be around much.
