will a 97 tranny fit my 93 mark VIII tranny
nieco
warner robins
I own a 93 Mark VIII and the tranny went out. I was informed that a tranny from a 97 model would work no problem as its the same tranny. I just want to makw sure that everything else on it will match up
Nieco
i see your a noob...welcome to the site, but will it fit....YES, but you need to take the 93's harness and swap it into the 97...or repin the harness from the 97 to the 93 style...this has been covered here many times, do a search you will get tons of info...and 98 and up trans are preferred
i did the 97 swap into my 93 and have had no problems thus far. Be sure to use your tcc solenoid, wiring harness, and the black box(shifter position box) on the side of your 93 trans. While your at it go ahead and Jmod the 97 trans to get the shifts you need.
