Will it fit? (Thats what she said!)
BigJohnson
Greenwood
Sorry about the odd title... was watching "The Office".
Anyways, I have to replace the back seats in my 03 LS but I was just wondering if anyone knew if the back seats from an 05 LS will be an exact match? Also out of curiosity, would I have the necessary connections already established behind the stock 6 disc radio to swap it out with one of the touch screen radios that come stock in the LS's? Could I swap radios if I bought the corresponding harnesses or are the electrical systems completely different and no way it would work? I have a 7' touch screen Pyle and two Pyle TVs in the headrest currently but the head unit is a "Pyle" of poop and Im embarrassed to even admit I have one in the Lincoln.
Yes and yes, but with considerable expense. You would be money ahead to install one of the better aftermarket units.
Yes to the seat.
No to the factory nav. (The only stock touch screen radio)
Things you need at a minimum to add factory navigation are:
Nav head unit
Nav DVD drive unit
DVD map
Sub-woofer amp
Four channel amp
Multiple wiring harnesses
GPS antenna
If you want voice control (factory systems have this) add:
Auto dimming mirror with factory microphone (used only on nav equipped cars)
If you want the steering wheel buttons to be labeled and work correctly add:
nav option steering wheel button assembly
If you want the full THX sound add:
THX door speakers (4) and subwoofers (2)
