Will these work
Ya, there the right bolt pattern. The size of tire you go with will determine if you have any problems with rubbing.
correction...
SoonerLS said:
That offset (35mm) is way off: the LS uses a 60mm offset. You're asking for trouble with that much of a change (1"). I'd keep looking; there are lots of great looking wheels that can be found with an offset that's much closer to stock.
2000 LS has 35-45mm offset and 5 x 108 lugs.
D r e w
