window problem
daves2000ls
AR
the front passenger window wont roll all the way up. it will go most of the way but the back corner of it will not go over half an inch from all the way up. i cant wash the car without water getting in, and at highway speeds the noise is overpowering. i can open the moon roof and the noise will go away. but i was wondering whats up on it. is it just of the track? is it an easy fix? should i take it to the dealership? what should i do to get it fixed? thanks guys.
its the window regulator. you can do it your self but if you have warranty just take it to the dealership. check teamford to the right they have it listed with prices.
Sounds like it's out of the track. Removing the door panel should tell you. If it is off track, it should be a simple fix.
my window is broken too. Ive asked numerous times....does anyone have the part number and instuctions to fix this yourself?
