cpgoodman
Ok, i did a search and came up with the answer to my problem. My window regulator broke on my driver door. I heard the crunching noise when i tried putting it up. I took the dooor panel off and saw a broken peice of plastic by the back of the door, looks like it i has something to do with keeping it on the track. Anyways my question is. Does the whole window have to come out to fix the regulator. When the door panel is if there is a big sheet of metal bolted to the door and the window is bolted to the back of this. On the front of this metal is the speaker and a black box the the harness's plug into. It looks like it should unbolt and come off. Any advice on how to go about fixing this would be appreciated. Lincoln wants 375 to fix it.
