boodaghost
Hows about this............. Wipers only work on the highest speed. Then, stop wherever you turn them off. If you time it right, you can get them to stop below drivers field of view. Relay??? Bad switch??? Help!!!!
CSimonGo said:I have a similair issue with mine..
When on they only work in the higher speeds, the delay does not work.. And when you use the turn signal they stop working sometimes.
Any idea's ???
mmmmmhmmmm about 90% sure1wykdmk8 said:Sounds like it is the multi-function switch to me.....anyone else confirm?
