wiring help
MaRk32v
joliet
i have a 95 mark viii with a just recently dropped in 96 motor. now i have been in the midst of putting it together over the last couple months. now just this weekend it all got dropped back in the car and all the wiring and everything is hooked back up. but i have a big problem now. when i got the motor from a junk yard and they hacked up the wiring big time. but i souldered in all my wiring and everything is all good or so i think. now the motor cranks over but im getting no spark. tried chanking over coil packs. and everything. i read in another thread that the fuzes could be blown. so i checked those now the only other thing is that there is a connection that runs down the driver side of the motor that has like a 4 way split. one runs to cam sensor, the other runs down by the oil filter one to under the fuze box under hood and other to the motor. now the one that comes off the fuze box to the motor on my 95 had only 2 wires and the one on my 96 motor had 4 wires now i checked a bizillion times to make sure i didnt need to solder in a different connection. would this deletion of the 2 wires make so i dont have spark. the only thing i dont have done will be the crank sensor which is about to get done. but if anything else should be checked please write back soon
i changed out the crank sensor and no luck. i think the only difference between obd I and obd II is that there is some vacuum stuff and obviously those 2 wires i had no luck with. anything else that could be wrong?
well i dont see 4 plugs but i will have to check on that cause another guy i talked to said that the fact that i didnt have the o2 sensors plugged in at first would be reason for it not to fire.
