Can someone please provide me with the wiring configuration for the harnesses going into the rear deck amp in a 2002 Lincoln LS? I'm going to be hooking up a bass tube in mine and 1) I need to install the line convertor for RCA pre-outs so I need to determine the left/right positive and negative outputs, and I'm curious about wiring the remote to whatever that amp uses as its remote. I would think that turning the radio on turns that rear amp on, which would be fine with me. Please if anyone has access to it, all I really need is the wiring info on the amp...
Thanks
Thanks
