WTB 93 Drivers Side Mirror
Green Machine
St. Paul
Anybody have a 93 single plug drivers side complete mirror w/memory for sale? Any color will work, but it needs to be a 93. Thanks.
The local U Pull here has a pair of 93s, I'm going as soon as my new windshield knife shows up hopefully late this week. If you still need one by then I'll see if I can grab one for you.
I might just have that but it's going to be black. It is a 93 but I can't remember if I took it off the car before we covered it up or not. I know I got the drivers side off because I used the casing for my 94. I'll go check and see if it's on there. If it isn't, it was burned up in the garage because I don't have that part in my closet.
Ok, I checked the 93 out back under the blue cover you see out in the background and there isn't one on it so it must have burned in the garage. Tomorrow, I'll look in the tool boxes to make sure I didn't put it up in one of the drawers.
i need the other side.
Damn, you did say drivers side lol. Do you need the shell or wire and all? I might have saved this stuff because I swapped them out on the 94 and the insides had to be removed because of the single wire connection. It seems like I put the 93 insides inside the 94 housing but I'll have to look when it's daylight because there isn't any power in the garage. If it's all in the tool box, it lived but if I left it out, there's no tellin what happened to it.
Some stuff just got dirty and some of it melted. I remember saving it but not sure if it was out of harms way when the fire started.
UHHHH, You sold that to me! burned Mirror and all! :)
That was off the 94 under the clear plastic which is the one that I took off the 93 way back there under the blue tarp.
BTW, did that piece you needed work for you. I sent everything because I didn't want to break anything trying to get what you wanted off lol.
