zachy
zachy
mesa
Hi I am the proud new owner of a 1988 Mark VII LSC. Just went through and replaced everything on it and now just need to find a manual on how everything inside works - any info appreciated. Thanks:)
Check online and boneyards for the manuel,someone on here might have one for sale,everything is pretty easy to understand about the gadgets on the inside,if you like racing you will want to learn how to shift it and mahe it pull threw second gear,always turn off your air suspension when the car is going to be jacked up,there is a switch inside the trunk.you have a button for your antenna to put it up or down,just sit back in your ride for a hour and play,you will figure it all out,enjoy
