SleeperMark
Hi guys. I have been searching for a fix to this problem since I bought the car. I have bought part after part with no avail. I have replaced upper and lower intake manifold gaskets, throttle body gasket, IAC and IAC gasket 2x, egr gasket, rubber T on throttle body, Cleaned throttle body and made sure it was shutting all the way, PCV hose elbow and valve, cleaned MAF at least 20x, converted tranny to Mercon V and replaced 1-2 shift accumulator and springs. None of these helped. I forgot to mention in the video that the tranny always wants to upshift early causing the car to bog out really bad but if tou just tap the brake it downshifts to the correct gear. It also always feels like you are a little on the gas until you come to a complete stop. Thank for the help. I cant imagine how happy I will be to get this fixed!!!
Here are the links to my videos. Thanks in advance
IMG_0039.MOV - YouTube
IMG 0040 - YouTube
IMG 0040 - YouTube
