parmaredmen16
Ok so I removed the 36mm crush nut and now I can't get the axle to break loose. Yes I did try a sledge hammer , any suggestions please.
This thing is the ****. I think you can rent one for free at autozone
thanks ,I didn't think of that..I'm on my way to autozone.
Yeh, that looks like a good idea - if you can't beat it, screw it! :shifty:
20 pound sledge......
Are you also known as Ripped Camel?
Why not recap what you are trying to accomplish?
You can also break it loose by using an air chisel. A guy showed me this. He just put a pointed tool in his air chisel/hammer, put the tip in the end of the halfshaft, and then pulled the trigger. It worked real well.
Wasn't there some guy on here had same problem? Thought he had to pull the knuckle with axle stuck in it and replaced it with other used one.
