chris2523
93 Mark VIII
Busted out the purple power and power washer. Washed the underside of the engine. I'm looking for a leak.
Removed these,
Installed these,
Then finally all back to normal, just missing the seal because I hadn't cleaned it yet
Removed these,
Installed these,
called the local stealer looking for the snap ring that holds down the spring cover around the threaded piston shaft on the rear caliper...no rebuild parts available from Ford but he can order me a re-manned caliper for just $368
Really. Lordco here has the rebuild kits for under $20. Rock Auto has any number of rebuilt calipers cheap too.
were they inside a body?found bullets in my trunk
Glad to hear it Chris! Those bags are fine. They made it 863 miles to your house. Just replace the ride height sensors for now. It's much easier.
Or you could just swap em' out for some new struts and be done with it.
After changing the PCV, replacing all the Chrome molding, cleaning the carpet, I gave her a good rub down with her favorite Maguire's. Not bad for a Chick !!![]()
