col batitong
Hello everyone, The day had finally come regarding the replacement of suspension parts. I was changing the oil of my LS and noticed that my front passenger side tire had some wiggle, upon further check, I saw the tie rod boot is bad. I checked further and looked to all the bushings and ball joints and all are needed replacement. They all dry rotted and breaking apart. I am thinking of doing everything including sway bars, I went to the Stealership quoted me for a whopping $2200:Bang:bsflag::eek2: just for Upper and lower ball joints, outer tie rods and alignment ( front only).
I saw this on eBay http://www.ebay.com/itm/150960569568
and its way cheaper, I will be getting 16 piece suspension kit $676 free shipping. I'll just replace everything while I'm there.
BRAND NEW
16 piece SUSPENSION Kit
FRONT + REAR
for
LINCOLN LS
2000 - 2003
16 piece Kit Includes;
FRONT
1 x Front Upper Control Arm with Ball Joints & Bushings LEFT
1 x Front Upper Control Arm with Ball Joints & Bushings RIGHT
1 x CONTROL ARM With BALL JOINT ASSEMBLY (STEERING KNUCKLE/AXLE BEARING CARRIER) (LOWER -14MM)
1 x Front Lower Control Arm Bushing LEFT
1 x Front Lower Control Arm Bushing RIGHT
1 x Front OUTER TIE ROD Left
1 x Front OUTER TIE ROD Right
1 x FRONT SWAY BAR / STABILIZER LINK LEFT
1 x FRONT SWAY BAR / STABILIZER LINKS RIGHT
1 x FRONT SWAY BAR / STABILIZER BUSHING LEFT
1 x FRONT SWAY BAR / STABILIZER BUSHING RIGHT
REAR
1 x REAR TORQUE TIE RODS
1 x REAR SWAY BAR / STABILIZER LINK LEFT
1 x REAR SWAY BAR / STABILIZER LINK RIGHT
Any advice on the above parts if its good or bad will be really appreciated. Thanks.
BRAND NEW
FRONT + REAR
for
LINCOLN LS
2000 - 2003
FRONT
REAR
