jrdnhsnbrg
Evening gents, story time with jrdnhsnbrg.
Last Sunday I was driving to brunch with my girlfriend when I heard a funny noise coming from my right rear brakes. It sounded like a whooshing, or a plane going overhead. It would only happen under 25 and most of the time wouldn't go away until I was back above 25, whether I was on the brakes or not. Got home, took off the tire and lo and behold, the inside pad was worn to metal. The caliper bracket that allows both pads to contact the rotor evenly was rusted in place, meaning only the inside pad was doing all the work. The caliper also was not retracting, you have to use a specialized piston turning tool because the caliper pistons are threaded. After getting this far we decided it would just be best to replace both calipers, caliper brackets, and pads and rotors. The drivers side rotor didn't appear to even have been contacted by the pads as it had a fair amount of rust where it should be shiny, and the caliper bracket was once again rusted to the point where it wouldn't move.
Pictures:
Passenger rear pads, top is outside with about 50% material, middle is inside down to metal, bottom is new.
Rear drivers rotor
Rear passenger rotor
All new hardware
Pictures:
Rear drivers rotor
All new hardware
