Wont happen. PATS, PK3, Sentry or any other OEM RFID system needs to see the Key RFID durring ignition power up. If this ID isn't present durring ignition power on, the ECM will NOT allow the engine to start. You can not turn on the ignition, and THEN try to show the ID after. So in other words, the code would have to be aquired prior to ignition power up.
In addition to this, Vehicles with RFID, or any other sort of immobiliser, will put themselves in a "theft lock" mode after a set number of failed attempts. For instance, on the Ford PATS system if the code is not aquired within a few try (cant remember exact amount, but its less than 6 im sure) The PATS system will not recognize anything for 10 minutes, EVEN IF IT IS THE CORRECT CODE! This is also why the dealer has to program a PATS key if you only have one other valid key: Even with the dealer computer, when programming a second key to any PATS equpped vehicle, the NGST computer makes you wait 10 minutes before programming the second key. (Of course if you have 2 keys to begin with, programming takes a matter of seconds).
So, basically..... what im getting to is..... It's not happening unless the thief is planning on spending a decent amount of time in your vehicle.
