00 LS sport heat and air control
5at38off
madison
the lights for both of my blue down arrows are blown out. is there a way to get in there and replace the bulbs??
mine too. i took the stock HU apart to use the bezel, and noticed all the LED's hardwired to the circuitboard. If that climate control module is similar, then yes it could be done. but not by just pulling a bulb from a socket. You'd need basic knowledge of soldering.
of course, this is all on the assumption that you can take that module apart. I never looked at it closely.
sounds like it would be on the circuit board since the radio has the same green lighting as the climate control. im not going to bust it open so I will have to live with it... at least both my blue are out so it looks factory if you didnt know better..
