02 Lincoln LS Low Beam Headlight problem
did wind up fixing my headlight issue.
symptoms we're one headlight worked and one highbeam, and opposite on the other side. There was no power to the related fuses in the passenger footwell fusebox.I did find many super corroded wires along the front harness/headlight jumpers but ultimately it turned out to be the ssp2 relay in the trunk was bad.
go figure, hope this helps someone else down the line.
Had to bump this. Have the same problem. Both low beam hids (aftermarket) stopped working. Pulled fuses and both were blown. Replaced them and swapped out the ssp2 relay and now the passenger side works fine but the drivers side fuse keeps blowing....any thoughts?
Ok so I've been dealing with this problem since I got this car a few months ago and I figured it out guys well at least I think most of you could use this info rest might actually have something wrong, so turn ur lights to left to auto and it was saying my bright were on so I just pulled the turn signal lever towards myself and the brights click off and low beams click on !!!!!!! I know I'm not brightest mfer' but my grandma always said boy u ain't bright but u sure are handsome hope this helps ,,,the lights thing not my grandma nvmnd
everything else works...fog lights, high beams, turnsignals.
Look I had same issues, then I figured it out today,try this , turn ur lights switch to the left in auto then ur dash should have the brights signal on ,pull the turn signal lever towards you and bamm ur brights should go off and low beams on !!!! Hope it helps brotha
