I have a 2002 LS with the V8. The camsaft sensor needs to be replace, but I'm not sure where it is. Can somone let me know where it is?
Gen I only has one. I found out that it's on the driver side closest to the fire wall. I pulled the codes and it gave them the code for the camshaft sensor, plus it idles ruff, takes a couple cranks to start and its running lean.
P0340 was showing for the camshaft position sensor circuit and PO171 saying the system is to lean.
