Hey joegr think that Oring is not the one I need. Here is a picture. I need the oring that's between the thermostat housing and the front plastic piece where the coolant cap is on.
The manual refers to what you called "the front plastic piece where the coolant cap is on" as the Thermostat Housing and "the thermostat housing" as the Coolant Outlet Pipe. However, to make things interesting, in the parts list, they're referred to as the "thermostat cover" (
3W4Z-8592-AA) and the "thermostat housing" (
3W4Z-8548-AD) and ... on the Ford site "
Connection - Water Outlet" and "
Tube - Water Inlet".
Lesson here is to be as descriptive as possible; i.e. "gasket between the the thermostat housing and the piece behind it" is understood as something else.
Joe quoted the correct gasket: 2W9Z-8590-AB (#8, in the first diagram below).
Ford |
Tasca |
RockAuto (cheapest, and there's also a Mahle version for $1 - no comment)
2006 Lincoln LS Workshop Manual
Item Part Number Description
1 15161 Auxiliary coolant pump-to-thermostat housing hose clamp
2 18K580 Auxiliary coolant pump-to-thermostat housing hose
3 W503925 Lower radiator hose support bracket bolts (2 required)
4 15161 Lower radiator-to-thermostat housing hose clamp
5 8B273 Lower radiator-to-thermostat housing hose
6 W500014 Thermostat housing bolts (3 required)
7 8594 Thermostat housing
8 8A571 Thermostat housing O-ring seal
<- what you're looking for
1 9F813 Throttle body heater hose
2 8276 Degas bottle hose
3 15161 Upper radiator hose clamp
4 3W43 Upper radiator hose
5 W500015 Coolant outlet pipe bolts (4 required)
6 8A504 Coolant outlet pipe
7 W707299 Coolant outlet pipe seals (2 required)
