tosaman
My Nav has over 175K on it, and I've been dealing with air suspension problems for a while. Last year I replaced the front air bags struts with after-market units from Suncore (they're okay) - also new solenoids just to be safe. Then the compressor went out - replaced that this spring. Recently, a height sensor went bad and replaced it (Rockauto). Unfortunately, that repair required the system to be reset, and that only can be done at the dealer. After a very bumpy ride to the dealer I was informed that there were three failed attempts at getting the system to reboot and that my control module was bad. THAT DID IT!
I finally bit the bullet and ordered the Unity coil conversion kit from Amazon ($320 free shipping). I had recent arm surgery so was forced to have a local shop install them -- 4-1/2 hours labor per the book, but a very easy DIY project. Anyway, I am very pleased with the conversion -- should have done it a long time ago! The ride is a bit different, but certainly not worse than with the air suspension. Frankly, I was a little concerned about that based on comments made by others, but the ride is fine. My wife hasn't noticed any difference, and she's the one who likes a soft ride!
Regarding the air suspension warning message, Unity's site says that the dealer can turn that off with their computer as some Navigators were sold with conventional suspensions and they all have the same onboard computer. I'll take care of that when I go in for my transmission servicing. Saves the effort of hunting for and cutting wires as recommended by other sites.
My message is this -- don't invest a nickel into repairing your air suspension system -- it's a money pit! I personally think that anyone with a high mileage Navigator should maybe do the conversion even if they haven't started to have air suspension problems, which will happen eventually. It will be more convenient and less costly in the long run. Just saying...
