MediumD
Tire spin does not make you go faster...
Cbecker1994Vlll said:don't really care about budget on the stroker kit. i just want a good one. i already got the AFR heads torker 2 intake and a 750 demon carb. its going in a 89 mustang coupe it will be mostly drag strip and very rare street use
The Professor said:Edelbrock's Torker II is a single-plane, low-rise design that provides you with top-end horsepower without affecting the mid-range. What Edelbrock did was increase the plenum volume and alter the short-side radius of the runners, to give the air/fuel charge a straight shot at the intake valves. That straight shot produces a potent power build from 2,500 to 6,500 rpm. It's a much better street / strip intake than a Super Victor - the 3500 - 8500 RPM range makes that not so good on the street but GREAT on the track.
Just keep in mind as cubes go up, the rpm ranges of intakes and cams go down. If your'e only going to spin it to 6000 RPM or less I'd say Torker II, if you're going more than that I'd say Super Victor.
m_maker said:My old 95 with ~ 350rwhp run 12.9 and trapped 108mph and that was with some tire spin.
I'd like to go to that track you guys go ... LOL
Dr. Paul said:Well, mine was in a mustang. 12.88 @ 111 mph. Only 347 rwhp, but 442 ft. lbs. of torque.Hooray for huge strokers.
Paul.
67Continental said:I dunno what to tell you, but this is two nights, weeks apart, now that I have run those times and traps....I photographed my timeslips.....I dunno what else I have left to prove to some of the doubting Thomas's of this board.
driller said:I don't consider myself a doubting Thomas, but truly just want to know how someone has a mid 14 second run with 100+ mph trap speed and my car barely traps 100+ mph running mid-upper 13s. I admit most times I believe my mph is on the low side, but others I know who run near the same ETs still only trap 101-103 mph at best.
Is it tire spin? Cause I have none. Since I've been dragracing the Mark VIII, whenever I started having traction issues, I took steps to eliminate any tire spin. Anytime I've had traction problems, my times were inconsistent.
