Right on the Mark
End of story.
I went 12.47 best N/A couple months ago. Let's see what you run. Make sure you add it in here so I see results. Best of luck.You were running the 4.10s, 3400 stall, And an Un-ported gen 1 Intake when you ran mid 12s n/a right? Can I expect similar times with my combo? 4.10s, Kooks, Ported Cobra Intake, IMRC Deletes, 3400 stall, A/C delete, and gutted? Or do you think it isn't realistic to expect a 12 second time slip
End of story for 2017 I meant.It's only end of story till next year
When you both take your cars out for one day at the track again .
Get ready? lol I'm already ahead of you. YOU are the one that has to get ready. Must suck always not being #1 huh?Bar going way up this year. Your 60' and annorexia is the only thing that saved you. Get ready son.
How did that work out for you? LOL
I didn't even need to take car out this year to still clean his clock! lolIt's only end of story till next year
So what happened?? Been waiting for an update.I'll have new engine in car within th next month. After it's tuned I'll take it to the track. Hoping to run high 12s. Thanks man
My wires are laid out like they should be. Sometimes its hard to follow where they go from pic. That intake box is a 90's Mustang 5.0 March ram air box. You can see my thread here Mustang March Ram Air Install Picshow is it that your ignition wires on passenger side coil are run differently than both of my 94's? is there a trick to changing the factory firing order? also,what or where is that air filter box from?Thanks
