17" 5 X 108 (4.25)) MODA RIMS
HoosierLs
Fort Wayne Indiana
I have an 06 Lincoln LS. Found a set of Moda rims that came from an 01 Jag S-type. Will these be a bolt on to mine. I kno the bolt pattern same but what about the offset and the wheel hub? Thanks!
If it fits an S-type, it fits an LS. Same base brake size, same stock +60 offset, and gen 1 S-type uses the same suspension parts. Even the S-type R staggered wheels fit with +60 all around
Awesome thanks for the info. What about some 19 in Ford fusion rims. I only ask because some of the Google sites aren't real specific and I have to make quite a nice drive to get em. Just looking to get thru winter. Thx again
2013-20 Fusion rims are a good fit for the most part with similar widths, +55 offset, and even tire height. However so far the 18s I've seen needed a 3mm spacer to clear the face of the calipers due to spoke shape (nothing to do with offset)
1st gen fusions are the wrong bolt pattern, 5x114.3
