1994 Mark viii idle issue
BigUziLinc
Vancouver, B.C., Canada
Hi everyone,
I have an issue with my mark viii where the car idles very rough at 500rpm where the whole car sways side to side and has a loping idle that goes up and down ~50rpm. Also on the first start the car will rev up to 2k rpm and then stall, the second start it will struggle but will manage to keep the car running until it warms up to operating temp and then will stall. Once I start it again and leave it by itself it’ll idle with the above mentioned issue.
Once the car is warm and I go WOT it rev hangs ~1000rpm and then it starts to idle normally and very smoothly at ~650rpm but after a minute there’s a thud and the idle drops to 500rpm and becomes very rough with the whole loping issue again.
This problem only started happening after having changed the IAC, maf, tps sensor, spark plugs, wires and coils with new ones. Prior to changing the parts the car would idle fine but a bit higher at around 650 rpm but would have a jerk of rpm and if I wasn’t pressing the brakes hard enough nudge the car forwards while idling at traffic lights.
I have replaced the spark plugs with new warranty ones and they are gapped to the factory spec, have thrusted with old coils and wires and the issue persists. I get no check engine lights but using a obd 1 scanner I get DTC that say lean mixture.
Sorry for the long write up and any help would be appreciated to help find what’s going on.
the crank position sensor goes bad often enough on these cars and should be changed as well. if that doesn't help, I'd look into the secondary intake flaps to see if they are shut at idel and only opening over the 3K rpm mark. if they are sticking, it sounds like what you have. Way too much air at low idle. the flaps are a pain to fix from what i read but maybe some one can chime in on their exact name and how to get them working again.
Here is what I was talking about. Those carboned up round flaps should only open once the RPM's hit 3000 and above that they should be peged at WOT. If they are stuck as some have reported, you can get what Biguz is describing. Thats why its all ways good to do occasional WOT runs just to free them up time to time. a good running car will give you a noticable shove forward when those secondaries open up. My car is spot on at 3K with that.
