1998 Navigator suspension leanin to passenger side.
1998Gator
Jamesburg
Hi Everyone,
I need your help!!! Last night I replaced the rear lower control arms and the drivers side rear air bag. When I started the truck and turned on the air suspension, the truck started to raise which is good but the drivers side raised higher than the passenger side. It looks like the drivers side is about at max height and he passenger side is low or normal ride height. I checked the front passengers side relay and its fine. What do you think my problem is? Please help, I don't have money to take it to get repaired and I need this vehicle to get to work.
Thanks, Bob.
ride height sensor. that it what was wrong when I had that problem. Very easy to change also. I did not even jack the thing up and I had it changed in probably less than 15min. It think it was two bolts and an electrical plug. No trouble sense.
Mine just locked up and rounded out the cheap plastic it goes in.
worth a look anyway.
Hey let me know if the height sensor fixes it, i have the exact same problem. How bad is it leaning? mine is around 2 inches
